variables without indicators and controls
Is there a way to create a variable without having a indicator or control in the front panel. I just want to save and update data in the block diagram.
Thank You,
Venkat Rao
Message 1 of 35
(6,838 Views)
The best way would be to keep the data in a shift register or feedback node.
There are also shared variables.
Can you show us some code so we can give more specific advice?
Message Edited by altenbach on 08-17-2009 09:04 AM
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 2 of 35
(6,827 Views)
That is exactly what a wire is in LabVIEW!
See alsohere.
Ben
Message 3 of 35
(6,826 Views)
I have attached the VI I am working on.
On the front panel there are two variable called  Top and Bottom Limit Variables. These variables get their value change inside the inner most case structure. This has no purpose being displayed to the user.
What is the most efficient way to change it?
Thank You,
Venkat Rao
Message 4 of 35
(6,809 Views)
Definitely shift registers!
Message 5 of 35
(6,804 Views)
Hi
you can use functional global
the another way is to create subVI (let say "ReadLimit.vi", His output is array of limits) and to wire it to shift register
Eugene
Message 6 of 35
(6,800 Views)
The value of the variables can change in either of the top or bottom case structure. how do I wire the variables to know which time to change?
Message 7 of 35
(6,799 Views)
Hi
It seems that functional globals can you help
But, change your main function pattern. use event structure.
Message 8 of 35
(6,794 Views)
Hi venkat_rao,
I'm not sure what you mean by "what time to change". Do you want to know which one to run or know which one wrote to a variable last or what?
Jeff | LabVIEW Software Engineer
Message 9 of 35
(6,753 Views)
OK, please tell us a bit more about the logic and how the various cases tie together. I assume that only one can be active (discarge vs. feed). If both can be active under some conditions, you would have several locations overwriting locals in arbitrary order with unpredictable results (race conditions!) This means you should have everything in one case structure.
There are other race conditions, for example you read from a local variable of the "data array" in parallel of the generation of the data array. Since things occur in parallel, there is no way to tell what happens first. Another race condition! To ensure that the case structure operates on the current values of "data array", you should use a wire instead of a local variable.
You also have several cases where you write to a terminal (e.g. ... valve open" in one case and to a local variable of same in the other case. Again, you should place the terminal outside the case structure and just wire the indicator to te same wire that goes to the case selector. No need for diagram constants and local variables. right?
Message 10 of 35
(6,740 Views)
