11-15-2007 01:00 AM
11-15-2007 05:43 PM
Hi Mordeye,
From the specification the expected behavior is a power-on output current of 0.0 mA. It seems like it was an issue present in previous versions of DAQmx drivers but it has been fix in the new release. What I would suggest is to download DAQmx 8.6.f12, where this issue has been addressed.
I hope it helps
06-08-2009 10:30 AM
Hello, I have the exaact same problem that Mordeye reported back in 2007 where the analog outputs from the NI-9265 default to 20 ma.
I am using it with LabVIEW 8.5 and Windows XP and I am wondering if any new way of fixing the problem is available now.
Thanks.
Pablo.
06-09-2009 08:57 AM - edited 06-09-2009 08:57 AM
What's wrong with the fix mentioned? Upgrade your version of DAQmx.
06-09-2009 09:18 AM
The link to " DAQmx 8.6.f12," leads nowhere!
Also, the file "DAQmx 8.6.12f" (posted in another knowledge base article) does not seem to exist but there are some other possible upgrades from 2007. I will like to know which is the upgrade that will work with LabVIEW 8.5 so I do not have to upgrade the entire LabVIEW package. Can you provide the name of the file to download?
Pablo.
06-09-2009 09:23 AM
Okay, I see the issue now. You could have said the link is broken in the first place.
The latest driver is 8.9. You can find all drivers by clicking the 'Support' link at the top of the page.
