09-06-2017 09:34 AM
Thanks again for your help tyk 007
i contacted multichannel systems today and they knew what caused the problem. so i can now use the tcx controller and have no more issues.
dears michael
09-06-2017 02:16 PM
Glad you have solved your problem. If you get a chance feel free to post the solution here in case someone else encounters the same problem.
09-14-2017 02:21 PM
The support of Multichannel systems provided me an example how to do it in c# programming and its the same way doable with the invoker nodes in labview:
CMcsUsbListNet usbDeviceList = new CMcsUsbListNet();
usbDeviceList.Initialize(DeviceEnumNet.MCS_TCX_DEVICE);
CMcsUsbListEntryNet entry = usbDeviceList.GetUsbListEntry(0);
using the .net dll provided from the mcs webside all those functions are imported to labview.
and using the commands above the connection to the tc01 thermocontroller works.
