using a current transducer to measure the current with 0 to 5V output using a data acquisition module to connect to labview through modbus tcp/ip
Highlighted
Hi
I would like to ask how to do convert from decimal readings (data collected from data acquisition module to labview modbus) to rms current readings on labview? I am using a current transducer, CR5410-20 to measure the current. The input and output of this current transducer is 0 to 20A instantaneous and 0 to 5V respectively. I need to find the rms value of the current.
2019-11-14(1).PNG is front panel.
2019-11-14(2).PNG is block diagram.
Thank you.
(222 Views)
Accepted by topic author ace2light
Probably with the "RMS.vi" or the "RMS PtByPt.vi".
(189 Views)
See my solution to a similar question here
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
(162 Views)
