05-13-2010 07:29 AM
Hello
I'm fairly new at LV programmnig and i've tried to modify a project made by someone else that sends some data through the serial port.So the program I am trying to create needs to send data to the serial port by manual command or time based(using a timer to send data every "x" ms).The problem is that the sending is done in a event case and the event choosen (boolean indicator value change) does not select the proper case.Can someone please give me a hint regarding the way it's meant to be done?
Thanks.
Solved! Go to Solution.
05-13-2010 07:44 AM
05-13-2010 07:57 AM
Can you please further explain or maybe show me on the example i've uploaded?
05-13-2010 08:32 AM
Sorry for the double post, i've managed to do what you said, the only problem now is the fact that the property node triggers the event non-stop, no matter if the button output is true or false.(every time the button is read, the property node triggers an event).Is there a way around this?
Thanks.
05-13-2010 08:43 AM
