05-02-2016 05:17 AM
I'm currently writting a UI for Thorlabs LC100 Smart Line camera. I was able to finish a simple UI utilizing the single shot internal trigger mode of the camera inside a while loop, but now I would like to add an external trigger. However, I got stuck in operating the camera in single shot extrenal trigger mode inside a while loop. I'm currently having error shown in the attachment.
Can anyone help me solve this problem? Thank you very much!!!
05-02-2016 10:31 AM
Can you upload your VI (or zipped up LabVIEW project)? I'm using LV 2014
05-03-2016 12:44 AM
Here is my trial code for operating the LC100 in external trigger mode. I've already made a vi that works well using the internal trigger system of the camera. I'm using LV2010 and just starting to learn to code using it.
05-03-2016 03:41 PM
Well, I cannot see all your SubVIs since I do not have them, but I can give a couple of pointers. Do all of your Initialization and configuration before the while loop. It only needs to happen once at the beginning of the program. Close the camera after the while loop. You should also add a small delay using the Wait (ms) function around 10-100ms just so the program is not using 100% of your CPU.
