user press ok before going to next loop
saved it in LV 8.5 now.
But as I already mentioned, when you run the vi and you get a true signal.
You can only reset the LED for 1 iteration with this vi.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 11 of 19
(1,225 Views)
can i put all the leds into 1 arrary and blink the LEDS? Thank you.
Message 12 of 19
(1,203 Views)
You can pretty much do that by creating empty array in front panel and keep one boolean control/indicator.job done.
-Be careful about value you're sending to array, you need to build array of all your boolean wires and then pass.
uday
Message 13 of 19
(1,186 Views)
can u show me a example please? thank you
Message 14 of 19
(1,183 Views)
Please see the image attached.
uday
Message 15 of 19
(1,174 Views)
anybody know how to change the colour of the flashing LED? It's always Yellow. thank you
Message 16 of 19
(1,160 Views)
I don't know which LED you mean.
THough in most cases its just right click>colors
Message 17 of 19
(1,158 Views)
im gonna change all the led to blinking and i cant change the colour. As i create property node for my blinking led.
Message 18 of 19
(1,152 Views)
Check this out
Message 19 of 19
(1,146 Views)
