Im looking to see if anyone knows of user defined (?) aerospace icons/functinos. I'd like to represent column/wheel inputs and flap/elevator/aileron outputs with representative icons (e.g surface i.e flap icons instead of just waveform graphs). Does anyone know of any ?
There are a couple of examples that install with the Control Design and Simulation module that might help you. One is the simulation of an f14 longitudinal dynamics. The other is an example of Model Predictive Control (MPC) to implement trayectory tracker for an airplane. This examples install in
C:\Program Files\National Instruments\LabVIEW 8.6\examples\Control and Simulation\Case Studies\Aerospace
Javier, thanks for your advice. I found some useful inceptor (wheel & column) icons where you suggested. What would be really cool is if anyone knows of surface (elevator, aileron and rudder icons also).
