11-17-2011 07:31 AM
In my Proffesional development environment the option "Use localized decimal point" in the "Front Panel" category is working fine.
When I build an executable it is not working. Therefore I put (useLocalDecimalPt=False) to my application_name.ini.
But, still it isn't working. Every time the local symbol of the PC is active.
This is with LabVIEW 2010 SP1.
I know that it worked in previous versions.
Can anybody help me?
Richard
Solved! Go to Solution.
11-17-2011 08:25 AM
Is useLocalDecimalPt=False under a group that is the same name as your application in your INI file? Notice that the LabVIEW.ini file has a single group [LabVIEW]. This group name has to be the same as your executable name. If that is not the issue, please post your INI file so we can take a look.
11-17-2011 08:59 AM
The group name is the same as the exe name. See ini file.
I know that this file is correct because of the viSearchPath item.
Additional information: I use Windows 7 64-bit.
11-18-2011 10:03 AM
You are missing an "e" in the tag. It should be "useLocaleDecimalPt". My apologies for missing this the first time.
11-21-2011 12:33 AM
Thank you very much DFGray.
This did the trick.
Stupid me. But at the same time strange because I never changed it.
