(useLocalDecimalPt=False) in ini doesn't work for exe
In my Proffesional development environment the option "Use localized decimal point" in the "Front Panel" category is working fine.
When I build an executable it is not working. Therefore I put (useLocalDecimalPt=False) to my application_name.ini.
But, still it isn't working. Every time the local symbol of the PC is active.
This is with LabVIEW 2010 SP1.
I know that it worked in previous versions.
Can anybody help me?
Richard
(3,111 Views)
Is useLocalDecimalPt=False under a group that is the same name as your application in your INI file?  Notice that the LabVIEW.ini file has a single group [LabVIEW].  This group name has to be the same as your executable name.  If that is not the issue, please post your INI file so we can take a look.
(3,106 Views)
The group name is the same as the exe name. See ini file.
I know that this file is correct because of the viSearchPath item.
Additional information: I use Windows 7 64-bit.
(3,100 Views)
Accepted by topic author Richie_Kurvers
You are missing an "e" in the tag.  It should be "useLocaleDecimalPt".  My apologies for missing this the first time.
(3,080 Views)
Thank you very much DFGray.
This did the trick.
Stupid me. But at the same time strange because I never changed it.
(3,064 Views)
