use subpanel over Lan
HI!
Is it possible to use subpanel over Lan?
I found a same topic, but there was only a suggestion to use remote panel...
btw, is it possible? or not?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,618 Views)
Accepted by topic author D60
A subpanel and a remote panel are two different beasts. A subpanel is not an independent entity - it is a VI front panel object, and as such must reside ... on the front panel of a VI. This it cannot be used over a LAN. The VI that houses the subpanel, however, can be.
(2,606 Views)
thank you!
[Hungary]
(2,603 Views)
