usb to serial communication
@Ben_Manthey wrote:
There's a known bug with USB Serial convertors.
http://www.ni.com/product-documentation/52366/en/#182027_by_Date
It's supposedly fixed in VISA 15.0 but I haven't had a chance to test it.
The user reported that the manufacturer-supplied application also does not work.  Have you tried swapping out the USB to Serial converter?
Bill
CLD
(Mid-Level minion.)
Message 11 of 13
(1,025 Views)
If you can't get the manufacturer's software to work, then that is proof this isn't even a LabVIEW problem.  You need to go back to the mfgr and work with them until you can get their software to work.  Maybe the problem isn't even the USB/serial adapter, but their device is broken.
Message 12 of 13
(1,023 Views)
So, it means that there is nothing wrong with your LabVIEW work. You should contact the manufacturer.
Actor Framework rocks!
Emre TUZUNER
Message 13 of 13
(1,007 Views)
