usb to serial communication
Hello everyone,
Im working on a project which has an device with rs232 port. I modified the basic Serial read-write VI. The program works fine with PC Serial port. But when I try to communicate with the same device through USB to serial converter (FTDI FT232RL FT232 USB TO TTL 5V 3.3V SERIAL ADAPTOR FOR ARDUINO BE0027) that's not happening and I get error message saying VISA read error. I searched forum for solution but still im at same problem.
pls help me out to solve with this problem.
Thanks.
Message 1 of 13
(5,350 Views)
Hi reva866,
Can you share a code or a snippet so that we can help you?
Emre
Actor Framework rocks!
Emre TUZUNER
Message 2 of 13
(5,346 Views)
USB to RS232 Serial converters are getting better these days but you may still need to try a few different models if you're interfacing to older equipment.  What device are you attempting to talk to?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019 - Unfortunately now moving back to C#, .NET, Python due to forced change to subscription model by NI. 8^{
Message 3 of 13
(5,305 Views)
RS-232 is a pretty loose and "sloppy" standard, so two devices which are both following the standard might very well not be able to communicate. I had a similar thing happen to me, where a JLink couldn't communicate with mu USB dongle, but worked with the motherboards serial port, but not on the next computers port ... So, try with a couple more. 😕
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 13
(5,291 Views)
Its the same vi from examples (Basic Serial Write & Read). The same program throughs "Framing Error during data transfer" error when I use USB to serial converter. What could be the reason for this. Pls help out.
Message 5 of 13
(5,265 Views)
I use FTDI- devices a lot and it's quite reliable. Look at my settings:
Driver Version 2.12 is quite new, but not essential
Klick this Button to configure the FTDI- Chip (the other settings are configured by your VIs settings)
These are my settings. No problems.
Are you using Handshake (XON-XOFF, DTR-DSR)?
Greets, Dave
Message 6 of 13
(5,252 Views)
After doing these setting my error remains same (Framing Error). The baud rate, start bit and everything are set correctly. The problem Im mainly getting is that when I run it, sometimes it starts with a random symbol or character, and then it stops running and tells me I have a framing error. Sometimes as well, when I start it, nothing happens at all, and then after a little wait, it says I have a timeout error.
Pls help out
Message 7 of 13
(5,223 Views)
Hi reva866,
Can you send/read data using a software like Putty? Like others say, you may have a problem not caused by LabVIEW.
I suffered a lot in the past because of the converters too. then I started to use this converter and I never had a problem.
Emre
Emre TUZUNER
Message 8 of 13
(5,220 Views)
The device has communication exe supplied by the manufacturer. with that also it is not communicating,
Message 9 of 13
(5,216 Views)
There's a known bug with USB Serial convertors.
http://www.ni.com/product-documentation/52366/en/#182027_by_Date
It's supposedly fixed in VISA 15.0 but I haven't had a chance to test it.
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Message 10 of 13
(5,204 Views)
