usb 6009 acquisition fall after 15min
Like it's said on the name of my post i have some problem with my new usb 6009. When i start it all work good but after a while my two AI fall to 0V. I put my code in joint pieces. I use AI0 and AI1 with a 220ohm resistance.
Thank you
Samuel Rioux
(2,393 Views)
Hi skling,
DON'T use an additional Wait function when you have set your DAQmxRead to use a certain sample rate!
It will wait on it's own and after some time you will miss to read samples in time...
(2,392 Views)
OK i will try this.
thank you
Samuel Rioux
(2,375 Views)
