04-11-2008 04:10 AM
04-11-2008 04:19 AM
Hi mathan,
try this.
Mike
04-11-2008 04:25 AM
04-11-2008 04:28 AM
Hi mathan,
it depends in your dll. You can connect it as array or as five separate values.
Mike
04-11-2008 04:31 AM
04-11-2008 04:31 AM
Hai mike,
The dll was configured to get input as unsigned 8 bit integer only. That's why i asked to seperate the string into 5 separate ones.
Thanks & Regards,
Mathan
04-11-2008 04:34 AM
Hi mathan,
you can use the "Index Array" function from the Array pallete and resize it to 5 outputs.
Mike
04-11-2008 04:47 AM
04-11-2008 04:48 AM
04-11-2008 04:50 AM - edited 04-11-2008 04:50 AM
Hi mathan,
the index says which element (starting from 0 for the first) you want from the array, so for the first value connect 0, for the second 1, and so on. 20H should be index 0.
Mike
