You can edit your posts only for a limited time after posting.
I am not familiar with the properties you are using here. Where does the reference come from?
Typically, code is difficult to debug from images alone, it would be much better if you could attach some code.
If you have other problems, just post the in the forum so everybody has a chance to reply. I'm usually here so I will see it too.
