12-21-2022 07:54 AM
my lab has had a very old installation of license (2008?), and I recently got an instrument and labview driver, but it required a 2016 or later installation of labview to run. I upgraded the computer from Windows 7 to Windows 10 and installed the current version of LabVIEW. (My university has an updated license for LabVIEW, but my lab never bothered to upgrade before... its an academic lab).
however, now labview doesn't seem to recognize any DAQ devices. we have been using an SCB-68 for DAQ. When i go to device manager and click data acquisition decies, PCB-6035 shows up (this confuses me...). The same shows up looking on other computers that I haven't updated.
Any suggestions? I have not used LabVIEW in some time. The instrument I want to run has a serial input via USB and a driver that requires LabVIEW 2016 or later. When I tried to run it, I got an error, and got bizarre results checking it with CoolTerm.
12-21-2022 08:19 AM
Hi y,
12-21-2022 08:57 AM
As mentioned, after installing LV you need to install DAQ-mx. DAQ-mx only registers to the LV's that's already installed at the time. (If you need several LV version, you can install them all and then do 1 DAQmx. Also 1 DAQmx typically supports 4 LV versions and you can only have 1 installed of those.)
The 6035 is an old card, but from the DAQmx 19 readme i found it's still supported, but i'd assume DAQmx 22 doesn't support LV 2016, so double check before installing.
01-09-2023 09:14 AM
As other people have said, you may need to update your DAQmx.
Additionally, I've had problems before where, when switching between versions of LabVIEW, some of the old files stuck around during the update and caused problems. If this is the case, the best solution that I've found is to completely uninstall all of your LabVIEW files, and start again with a fresh download to avoid conflict between duplicate driver files. This can be a bit of a hassle, but there are how-to articles on the subject in the knowledge database.
