upgrade to ni-rio 4.0 and now i get project or library corrupt
I was running Labview 2010. I Installed NI-RIO 4.0.0 and now my project wont load. I get the Project or Library corrupt and the Labview just quits.  Everything was running fine up until that point.  If i change the name of the library so the load doesn't find it and tell the load to ignore it, it will fail on another library
I installed LV 2011 with no luck.
My project involved code on a PC, cRIO-9023, and trying to install a 9144 also.  The PC is running XP sp2.
Any help would be appreciated.
(1,895 Views)
Update: Uninstalling NI-RIO 4.0.0 fixed the problem.  The project loads correctly now.
(1,889 Views)
