05-03-2007 11:19 AM
05-03-2007 12:05 PM
05-03-2007 01:30 PM
You say you're using timed loops, so are you running this VI on a real-time target? If so, are the boolean indicators on the front panel of the RT target? Front panel updates have low priority on the RT and you might not be seeing all the boolean changes. If you're not on a RT target, you might as well be using a regular while loop.
Also, how fast do you want to run the loop to run? 700ms? Try to use counters for when they change state rather than relying on sight.
05-04-2007 02:49 AM
Hi
my software follows a producer-consumer design pattern. I post a (very) gross block diagram to make you understand how many loops there are and what they do.
Thank you
05-04-2007 09:15 AM
05-04-2007 09:44 AM
05-04-2007 09:48 AM
05-04-2007 10:02 AM
sorry, forgot to post
what do you think about substituiting the 4th loop with a case structure in which I can put the different updating procedures
(flat sequences in the figure posted) ?
05-04-2007 10:10 AM
05-04-2007 10:17 AM
