04-07-2008 01:24 PM
Hi gaga,
I know that with the complete LabVIEW package, there is an uninstaller. I think that you can use this uninstaller to uninstall the LabVIEW run-time engine. I'm attaching the Uninstall.sh file to this post for you to try out. Let me know if you have any questions.
04-07-2008 03:16 PM
04-08-2008 10:42 AM - edited 04-08-2008 10:44 AM
08-02-2011 02:46 PM
11-18-2013 03:39 AM
please I need a help, can you help me to give me the file comlete of uninstall of toolkit of labview 2012 because i have the same trouble but I cant Uninstall the anteriere version of labview run time 8.5
11-19-2013 10:53 AM - edited 11-19-2013 10:54 AM
Hi there,
First off - what operating system are you using? For now, I'm going to assume it's Mac since you're responding in this thread. To get rid of the Run-Time Engine (RTE) you can simply drag the RTE into the trash and delete it there. Also make sure to delete any dependencies that may still be on your computer.
03-13-2015 10:53 AM
Hi, this doesn't seem to work for LV8.6.1
I need to run two applications, one in LV6.1 and the other in LV8.6.1, both communicating via DataSocket. However, there seems to be a problem with the LV6.1 app using DataSocket v4.5 (installed with LV8.6.1) and I need to revert DataSocket to v4.0
Can anyone advise?
Many thanks
Deon Bester
SALT software engineer
03-16-2015 03:49 PM
Hi Deon,
This is an old forum post from 2013. I would recommend creating a new post about this question; this will probably get more visibility than this current post.
