07-01-2009 10:55 AM
I want to understand how the LabVIEW 8.6 project installer build generates and maintains the Product Code GUID. Is this generated new for every build of the installer? Here is some background for why I would like to better understand this feature:
Consider a small project that builds an executable: "my program.exe"
Create an installer for this program that includes the LabVIEW 8.6 Run-time, and puts a shortcut to the new program in the target "start menu > programs > my programs" folder. I wanted to put an additional shortcut in the same menu folder for uninstalling the program, "my program uninstall".
The first way I tried this was to wrap a system exec call in a VI and build it to a separate program, "my program uninstall.exe" that would install with the first. I never could get the uninstallation to work through system exec, however, with either the NI uninstaller (...\Program Files\National Instruments\Shared\NIUninstaller\uninst.exe), or the M$ program msiexec.exe.
Next, I decided to try to create the uninstall shortcut ahead of time, on my development machine, and install it along with the program. This seemed promising, as I could create a shortcut for msiexec.exe, and use the M$ documentation to call the following:
msiexec.exe /x {install.msi | Product Code}
Now, however, I'm faced with the problem of knowing what is the product code for my installation?
BTW, it was not easy to add a shortcut file to a project to get it to install with the project. I had to essentially strip of the file extension (.lnk) and set the shortcut to be renamed back with the extension in the EXE build.
Thanks anyone for advice,
James
07-07-2009 08:35 PM
Take a look at this KB
07-08-2009 09:46 AM
I have read that article, but it's not quite what I'm looking for. After pondering the problem a bit more, I came up with solution based around the NI Uninstaller. Follow these instructions to install a shortcut on the target machine to uninstall the package (Windows-based systems):
That seems to work; the only drawback perhaps is that it uninstalls EVERYTHING (LVRT etc + my program).
James
07-16-2009 03:22 PM
Microsoft's perplexing installer guidlines are something like this:
07-16-2009 03:31 PM
I forgot to note how to find you upgrade code. In LabView 8.6.1 it is stored in the .lvproj file.
1. Copy your project file and rename it project.xml or whatever.
2. Open in Internet Explorer or other xml editor
3. Find <Item Name="Build Specifications" Type="Build">
4. Open your Installerbuildspec. (i.e. <Item Name="MyInstaller" Type="Installer">
5. Find <Property Name="UpgradeCode" Type="Str">. Copy out the GUID, including braces.
You might be able to dig it out using a property nodes of the project from within LabView. That would be less gross. In any event you only have to do it once.
07-17-2009 03:35 PM
Rob,
Thanks for the breakdown and useful suggestions. I will definitely bookmark this thread as a good resource for later. In the meantime I've decided to rely on the NI uninstaller which can use the product name, and I've now hacked around enough to figure out how to get a proper shortcut installed to call it.
James
