10-17-2011 03:09 PM
I don't see a way to undo the binding of a <Return> key to a Tab Ctrl? Short of replacing the Tab ctrl, anyone have a soln?
This was done by the prior developer (apparently for no good reason). I spent at least an hour trouble shooting why the <Return> key was stuck on a FP boolean even after assigning other ctrls keyboard focus. This binding overrides any key focus properties set during runtime.
10-17-2011 03:27 PM
Your image is showing that a different control (a boolean) has the Return key binding, not the Tab control. You can go to the properties of that control to remove the binding.
Like you I find it a bit annoying when somebody else assigns key bindings, and I am giving the stink-eye to the system ok button right now.
10-17-2011 07:39 PM
Darin.K wrote:Like you I find it a bit annoying when somebody else assigns key bindings, and I am giving the stink-eye to the system ok button right now.
... just for those other readers who haven't seen this idea ..... 😄
