unable to select channels in VI logger 1.0.1
I am unable to select virtual channels in VI Logger 1.0.1 when I create a new logging task. I have several virtual channels set up in Data neighborhood and when I create a new logging task I do not see any channels under the virtual channels tab. I have been using this for quite some time and have not experienced this issue before. Has anybody experienced this behavior? Maybe I am missing something. I have tested all the channels and they are working fine. Seems to be a software issue to me.
(2,514 Views)
Did you make any changes before you started to see this behavior?  Did you install/unsinstall any software?
You might want to uninstall NI-DAQ and VI Logger and reinstall them both.  Let me know your results.
Sean C.
(2,495 Views)
