01-13-2014 12:05 PM - edited 01-13-2014 12:10 PM
hello,
i am using NI 9205 for data acquisition,but i have no external hardware trigger source, und i tried to use two digitital signal at rising edge for triggering stop/start sine signalgenerator,it runs Ok.
i wanted to use DAQ Assistent and Write to Measurement VIs to replace sine signalgenerator,one trigger start data acquisition until another trigger comes,and data acquisition is stoped,but it doesn't work.
can anyone give me some advices,the VI is attached. thanks in advanced!
01-14-2014 03:23 AM
Hello jetfire,
could you upload the SubVI's too?
Best regards
AndGar
01-14-2014 04:22 AM
01-14-2014 05:55 AM
@AndGar wrote:
Hello jetfire,
Best regards
AndGar
Hello AndGar,
i got SubVI's from this links
01-14-2014 09:33 AM
Hello jetfire,
could you elaborate what is not working? Do you get an error message when using the DAQ assistant?
I've taken your VI and simulated a 9001 card to get an analog signal in. In the aquisition mode "continoues samples" I receive error -200279. With "N samples" I can operate it. In all cases your program does not stop when your digitial inputs reach the end.
Best Regards
AndGar
