06-07-2009 05:40 PM
I am trying to figure out why my mail agent will not work I get an error and for what ever reason it does not make sense to me I hope sombody can help me.
here is a picture of both my FP and BD
06-07-2009 07:48 PM
06-07-2009 11:08 PM
06-07-2009 11:12 PM
06-08-2009 12:38 AM
Yeah I found that example I just figured there may have been a better way.
06-08-2009 10:43 AM
The reason you cannot simply use the SMTP email functions is because of Authenitcation.
I noticed the email you are trying to use has a .edu extention.
This means the email server probably uses SSL or TLS security, so you would need a little more code to handle that. Here is a thread that discusses this.
06-09-2009 10:33 AM
Also, do not use TLS (or SSL) security as a default.
This works fine if the email server uses this security, but otherwise will throw an error.
For example, if you use this VI to email someone with an AOL, Yahoo, email, there is no TLS security,
so it will be confused if you try to provide credentials.
Its kind of like handing in a typed CV when applying for McDondalds.
(That was probably an uncalled for analogy.... bad Cory)
