I am relatively new to labview and was in need of some aid; i have already talked to NI engineers and we didn'e come up with an easy solution to this, so please lend your expertise if you can.
I currently have a functioning program inside a while loop that I am looking to modify. I'm grabbing some waveform data and will perform some mathematical operations on it.
My question is what is the best way to grab that data in real-time and transfer it into another loop (which would do the operations on that data that i need). We tried some queue functions but apparently there were some timing issues, etc. that apparently didn't work. In case you are wondering why I am trying to grab this waveform data into a new loop, I will be taking averages of the maxes and mins of the waveform and calculating a new average every 4 seconds. I believe i can come up with an algorithm to compute this; its just getting the data to feed in accurately from the original waveform.
Please let me know if you have a way to do this or have any words of wisdom; it would be very greatly appreciated.
