transfer of the GPCTR0 output to a RTSI line(PCI MIO 16E 4)
I send this email so as to know if what I want to do is possible and how do that.
I have a PCI-MIO-16E-4 card, a PCI 1422 card, NI-DAQ 7.2.0f1 and NI DAQmx 7.2.0f0.
In fact, I produce a clock signal at the output of the counter 0 of the PCI-MIO-16E-4 card and I would like to transfert this signal on the RTSI bus so as to drive others cards. I used the "route signal.vi" to route the GPCTR0 output signal to the RTSI 0 line and the VI doesn't produce any error.
The PCI 1422 card is configured so as to trigger each buffer on a rising edge on the RTSI 0 line. However, the system tell me:"L'erreur -1074397150 s'est produite à IMAQ Extract Buffer.vi" and I don't understand why.
Is my method good or not or is it actually possible to route a signal to the RTSI bus?
Thank you
(2,049 Views)
You can look at this example
, which trigger images with the DAQ device.
Hope this help.
Isabelle
Ingénieur d'applications
National Instruments France
(2,044 Views)
