10-07-2008 07:53 AM
Stephen82 wrote:What you mean about transparent?When connect Elo touch screen to your computer, LabView how process and how connect to screen to detect user action?Do you work with TCP/IP,UDP connection or OPC Server. Please give me some help.
It is has transparent as using a mouse. It sounds have if you think this touch screen is more complicated than it really is. When you use an LCD touchscreen monitor, it installs a driver into Windows. That driver causes touching the screen to behave just like you were using a mouse. Nothing more complicated than that.
07-20-2011 07:15 PM - edited 07-20-2011 07:25 PM
I know this is an old post but I don't want to start a new thread of the same topic.
It is possible to control two touch screen panels using the same computer?
07-20-2011 07:32 PM
Is it possible to control two touch screen panels using the same computer?
07-21-2011 02:53 AM
Why not?
Your graphics adapter has two outputs and every screen add another mouse to the system.
Gabi
07-28-2011 05:31 AM
Thanks. My next question is that is it possible to programtically place a pop-up window on extended monitor/ouput?
09-01-2011 08:48 AM
Yes it is, --> VI Properties 🙂
09-30-2014 08:27 AM
This in this thread the connectivity of PC to a touch screen monitor is discussed, is the procedure same if working with PXI running windows 7.
Also how to get to know if a touch screen monitor from any vendor is compatible with LabVIEW.
09-30-2014 08:37 AM
The things discussed in this thread are as valid now with Windows 7 has they were in 2008.
09-30-2014 09:20 AM
We use ELO touch screens. The Elo drivers act just like a mouse. So there is nothing special you need to as far a programming, except design your GUI with touch in mind.
01-03-2017 01:39 PM
Hi everyone
I have a question regarding Touch Screen Monitor "TSM" product, as I am using one with cRIO system. I was hoping to get the pointer position as you would get mouse position on a Windows-based platform, but it seems NI has not provided anyway to access the pointer position or to get notified if the pen has been pressed (such as a mouse click on Windows based systems).
do you guys know what to do with this problem? any suggestions appreciated.
thanks
