03-10-2019 06:32 AM
Hello ,
I have to connect a touch screen with myRio .
So i can i use the touch screen of Raspberry with myRio? if not what else can i use?
Thank you,
Wafa Ben Mansour.
03-11-2019 01:43 PM
You can also use a regular laptop with a touch screen. Is there any specific hardware you were trying to connect to it?
03-13-2019 02:06 PM - edited 03-13-2019 02:07 PM
Many LCDs come with their own API usually through SPI. The myRIO has pretty good SPI support and by looking at the data sheet, and other examples, a display can be controlled. Keep in mind that there is no native display on the myRIOs operating system. This won't be as simple as plugging in a monitor. You'll need to write the code that draws the individual elements on the UI, as well as polling for touch positioning and figuring out what the user touched.
Oh and data dashboard might be an option if you connect to the same wireless network as a tablet.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
