In LabVIEW 6.1, when you create an installer, an uninstaller is automatically created. Refer to the LabVIEW Application Builder 6.1 Release Notes for more information.
In LabVIEW 6i, to create an uninstaller, you need to go to Tools >> Build Application or Shared Library (DLL)... >> Installer Settings. Check the Create Installer box, click the Advanced button, and check the Create Uninstaller box.
In both cases, the user needs to uninstall the program using Add/Remove Programs from the Control Panel.
Molly K.
Applications Engineering
Molly K.
Web Support & Operations Manager
