to create runtime library on labview front panel
Hello all,
I have create a library on front panel.so that during run time i can drag the element from library and drop it on front panel. for example if i want to add 2 random numbers. in run time itself 2 numeric controls and 1 adder can be dragged and dropped from library in run time.can i do this in labview?
Please suggest me the same.
Anuja
Message 1 of 9
(3,525 Views)
Let's be clear.  Of course you can do that in LabVIEW! But, how you approach the issue and, how complex the code will need to be depends on details you have not bothered to share.
Do you want drag n drop of images from a pre determined list of images.  Or are you try to generate appropriate outputs that represent the functionality of your pictures?
"Should be" isn't "Is" -Jay
Message 2 of 9
(3,511 Views)
What do you mean by "libraries"?
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(3,486 Views)
Dropping controls, functions, and connecting them?
So basically you want to create LabVIEW in LabVIEW?
Of course possible, esp. if you limit the options. I'd go for a picture control...
Maybe you should tell a bit about the use case. I assume you want to provide an interface to the users of your application that enables them to "program" something?
Message 4 of 9
(3,479 Views)
Certainly possible, but probably requires a lot of work, especially on the diagram side to generate the actual code. Easiest might be to parse it onto a math expression that can be digested by the formula parsing tools.
Note that Lego Mindstorms software is actually written in LabVIEW. Many (many!) years ago, there was a presentation by Greg McKaskle at NI Week about how it was done.
Can you explain in more details what problem you are trying to solve?
Message 5 of 9
(3,471 Views)
Yes actually it is like developing labview in labview and I want to provide an interface to the users of my application that enables them to "program".
I am writing a code to generate different modulation techniques like AM modulation,FM Modulation etc.
Now the theme is, user can develop it on my application by taking sine wave adding dc offset in it and then multiplying it with carrier signal to create actual Amplitude modulated signal. where user can drag and drop these components from library.
I know it will take a lot of time and work to do the same if it is possible. but i just need one simple example code so i will implement the same.
Message 6 of 9
(3,450 Views)
That's a problem. A code example will be either trivial and fairly useless, or not simple.
I'd go (if I had to) for a picture control. You can draw anything in it, and probably can get something to drop on it (maybe with a lot of creativity). Then you need to detect clicks in an event structure, do hit detection (either on a list of coordinates, or on a second internal picture control storing ID's in stead of colors). Then animate (redraw) the object(s) accordingly.
Of course I (or my customer probably) would consider alternatives first, as this will be at least a few weeks of fulltime work (for me).
We can post examples, but you need to specify one or more subsets of the problem. On what part do you need help? Note that any non-trivial example will need some sort of architecture, rocketing development time sky high. I'm not ruling it out, but we all have (paid) work to do.
Message 7 of 9
(3,438 Views)
So this is just a linear sequence of processing steps. How about a horizontal arrangement of picture rings. For each step, the user can select a specific processing step (or "none", i.e. just a horizontal line). If there are only two possibilities, it could even be a boolean with two different images. On the code side, it would be trivial, just a sequence of case structures, one for each processing step. You could even have multiple such "trains" that get "merged" at certain points using specific graphic elements.
Message 8 of 9
(3,430 Views)
If there are more then two options, I'd consider one or two tree controls. That allows drag and drop, changing order, etc.
For instance, populate one tree control with available modules, the other is empty. Then the user can (almost OOTB) drag and drop the available modules in the empty tree. That's over simplified, but a hole lot easier then an actual graphical user interface like a LabVIEW diagram.
Message 9 of 9
(3,426 Views)
