timestamp en multiples archivos
estoy adquiriendo señales y guardandolas en archivos LVM por separado.
los archivos separados se separan cada 10min.
en un principio todo funciona, pero al momento de separar los archivos se pierde la hora y fecha.
el HEADER muestra lo siguiente:
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings No
X_Columns One
Time_Pref Absolute
Operator Administrador
Date 01-01-1904
Time 1:00:00
***End_of_Header***
Channels 1
Samples 1000
Date 21-02-2008
Time 16:25,9
Y_Unit_Label Volts
X_Dimension Time
X0 5,94E+18
Delta_X 0.001000
Al momento de graficar con el READ MEASUREMENT el archivo muestra la fecha y hora erronea de 1904.
gracias.
(2,793 Views)
Hi odiaz,
In this part of the forum it would be better to write in english. Which function do you use to seperate your file? Can  you show us your code or a part of it?
Mike
(2,788 Views)
Hi, I am acquiring signals and save LVM files separately.
Separate files are broken every 10min, with WRITE TO MEASUREMEN.vi
In the beginning everything works (first file), but when separate files is lost time and date.
The following shows what HEADER
LabVIEW Measurement
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings No
X_Columns One
Time_Pref Absolute
Date 01-01-1904
Time 1:00:00
***End_of_Header***
Channels 1
Samples 1000
Date 21-02-2008
Time 16:25,9
Y_Unit_Label Volts
X_Dimension Time
X0 5,94E+18
Delta_X
0.001000
When graph with the READ MEASUREMENT.vi file shows the date and time of mistaken 1904.
Thanks.
(2,778 Views)
Hi odiaz,
how do you seperate the data and where do you get it from?
Mike
(2,775 Views)
Data are obtained from a DAQ (Vi Express).
write to measurement.vi write to multiples files.
Is configured as follows: (see .bmp)
Thanks.
(2,764 Views)
