timed loop period ceased working
I am trying to sample from a can card every milisecond, i have the period set as such, but the time spent in the loop/number of iteration says that the period is something around .2 miliseconds. why is this so? my program is attached.
Message 1 of 15
(3,260 Views)
Hi cld8812,
do you really think we can work through your block diagram???
First for CAN: Is your device (and bus system) able to respond within 1ms?
2nd for your vi:
There are some problems in it:
- You should never stop a vi by using the "Stop" function - because there's a while loop running endless... Wire the stop condition to the while loop terminal and you can get rid of that function...
- You use much to much local variables! Replace them by shift registers! And use those indicator terminals - atleast you can remove one local for each indicatorSmiley Wink
- What about left-to-right wiring? Having block diagrams only the size of a screen? Using flat instead of stacked sequences?
Message Edited by GerdW on 06-27-2008 03:52 PM
Message 2 of 15
(3,251 Views)
Reading the bold statements, i understand that the timed loop is running 5 times faster than it should. Is that correct???
If not, please refactor your code following Gerds suggestions. To add some points regarding performance/readability:
- If the analysis from the acquired signals takes too long, split up acquisition and analysis using another VI architecture.
- Try to avoid variables and sequence structures.
- Don't show all available data from nodes in the timed loop but show only the used ones.
- Your "Benchmark" does not benchmark the timed loop, but the timed loop including several array manipulations.
- Use "unbundle by name" instead of "unbundle" when using clusters.
... (many more)
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 15
(3,243 Views)
your correct, it is running 5 times faster than it should.
Message 4 of 15
(3,239 Views)
Ok, how many "missed iterations" do you count?
Norbert
Expert: Geometry
Message 5 of 15
(3,236 Views)
none
Message 6 of 15
(3,234 Views)
How many iterations will the timed loop make for each "benchmark"? Is it a quite constant value?
Please move subtract and division for your benchmark in the second sequenceframe which takes the timestamp after the timed loop. does it make any difference?
Norbert
Norbert
Expert: Geometry
Message 7 of 15
(3,225 Views)
movieing makes no difference, and it seems to be 145000-and 150000 iterations
Message 8 of 15
(3,220 Views)
So, the timing difference your benchmark should reveal is about 30s for 150000 iterations. Is that correct?
Is the application running under windows?
Norbert
Expert: Geometry
Message 9 of 15
(3,218 Views)
20.5 seconds, and its in windows under time critical priority.
Message 10 of 15
(3,216 Views)
