I am trying to establish a communication between 2 desktop RT systems. Both devices have 2 network-interfaces. One is connected to the LAN and the other interface is used for a direct deterministic connection via a cross-over cable.
RT-System 1 used as master in the time-triggered network (screenshot rt_time-triggered-network.JPG).
The RT-System 1 gets data via TCP/IP and write data to a time-triggered variable of type single. My problem is that RT-System 2 can't use this time-triggered variable in read-mode. When I try to start the application VI on RT2 (Client) the clock synchronization doesn't work correct -> timeout (screenshot time synchronization rt2.JPG). What is wrong in my application? How can RT2 (client) get the data from RT1 (server)?
I also have attached a screenshot of the project explorer (screenshot project_explorer_rt.JPG).
Thanks for help.
Kind Regards,
Joachim
