08-20-2017 04:59 AM
Get at wrong convertion using this code to convert time to timestamp.
I can't figure out why?
The wrong result is in the constant in the to right corner.
08-20-2017 06:22 AM
Working with a 24 hour and no am/pm. So you should have %H instead of %I and the %p should not be there.
Result:
%<%H:%M:%S%3u %d/%m/%Y>T
08-20-2017 06:40 AM
Still get 12 h format:
08-20-2017 07:09 AM
But it's not wrong anymore. Thanks 🙂
Is it possible to get the result in 24 hour format?
08-20-2017 08:17 AM
What I gave you was the format of the string input. That is what you need to convert to the timestamp data type. The format of your indicator is purely based on the properties of said indicator. Right click on the indicator and choose Display Format. You can set it to show the time in any format you want.
08-21-2017 01:41 AM
great 🙂
