02-27-2006 12:34 AM
Hello, Experts,
I have data of voltage output variance over long period of time. And I'd like to do a power spectral graph(voltage amplitude over frequency). Is there anyway I can extract that information without running the experiment again? for example use FFT first then...? or must I use a spectrum analyzer and run the experiment again?
if I can indeed use labview...what function do i use?
thank you for clarifying.
ck
02-27-2006 05:55 AM - edited 02-27-2006 05:55 AM
You could always save the Voltage data/ Analysis results using suitable 'File I/O' functions in labview.
Save the acquired voltage, read it offline using these file functions and perform spectral analysis on it.
Similiarly, you can also save the results of spectral analysis.
further doubts??, do get back
regards
Dev
Message Edited by devchander on 02-27-2006 05:56 AM
06-01-2007 07:50 PM
I have recorded a time series (a modulated wave train). I would like to determine the low-frequency components that modulate the otherwise very stable square wave signal. Is there an example available for inputing the wave train (voltage) and the sampling frequency for getting the dominant frequency of the wave train and the low-freqency component(s) the moduate the wave train via specral analysis? Your advice please.
Peter Liiu
06-01-2007 08:14 PM
