08-09-2006 01:37 AM
08-09-2006 04:36 AM
hi there
well, there a several ways to do this. the problem with the software - timestamps is the minimal resolution of 1ms. i'd suggest:
- wire a copy of the digital pulse train to an analog input channel
- wire a copy of the frequency converter to another analog input channel
- create an analog input task with the two channels (the sampling rate defines the timing resolution,make sure to acquire enough samples to see the response signal)
- start this task
- send the digital pulse train
to optimize your acquisition you can use another copy of the digital pulse train as a start trigger for your analog acquisition.
-> then you'll see the digital pulse train on one of the analog channels and the frequency output on the other one. both channels have the same time axis with a resolution defined by your sampling rate (~us depending on your hardware). then you can analyze the data.
search the example finder for examples of how to create tasks and triggers.
08-09-2006 07:31 AM
08-09-2006 07:38 AM
yeah, that's surely correct!
but make sure that the device is stable and that the delay dosn't depend from the pulse train.
