10-14-2017 02:07 PM
Can anyone please give me some clues in how to find tilt angles. I have developed a code to read the data. But now interested in finding the tilt angles.
Thank you.
Solved! Go to Solution.
10-14-2017 04:10 PM - edited 10-14-2017 04:28 PM
10-15-2017 06:46 AM
Thank you for the help. When I am running the code I am getting this error.
10-15-2017 10:24 AM
Increase the number of bytes to read. Ideally, the read would be automatically stopped by a \r\n, so you can put the not of bytes to read to 100 or whatever.
10-15-2017 01:53 PM
Thank you that worked. I have a quick question is the tilt angle same as azimuth and polar angles? I not, can you give me a hint to calculate them.
10-15-2017 01:58 PM - edited 10-15-2017 02:14 PM
With a new poster this time of year I played safe with a potential homework question.
For completeness and for other that look at the solution I'l come back and explain.
RA is Right Ascension Abbreviated with RA or a lower case alpha it is the angle Eastward (to the left if facing South) on a plane orthaginal to the Z axis. The second parameter for spherical coordinates is declination (dec or LC Delta) an is the angle north of the X axis. The distance would be the square root of the of the sum of the squares of the two Rho components.
And since I cross posted with the OP
EDIT
Assuming you gave something like a Game controller. Z is Up floor to ceiling through the center of the controller, X is the line passing through you body and the Z axis at right angles, Y is to your right. RA tells you how far the controller is tipped to your left, Dec tells you how far it is tipped toward you. You can't tell which way you are facing without two accelerometers, and lots of integration or a compass heading.
10-16-2017 10:12 AM
Thank you. I have calculated it differently. I want to know is there a way to represent all the 3 graphs of acceleration in one. I have a quick question about insta. acceleration, how to calculate it?
10-16-2017 10:21 AM
Use the context help (Ctrl+h) and hover above the graph terminal to see how you can set multiple graphs.
10-16-2017 01:32 PM
@bufferlab wrote:
Thank you. I have calculated it differently.*A I want to know is there a way to represent all the 3 graphs of acceleration in one *B. I have a quick question about insta. acceleration, how to calculate it?*C
A. No, you haven't you just duplicated the Complex to Polar calculations for angle.
B. Yes several
C. "Up" I really have a lot of fun when people ask me "Hey, Jeff! What's up?" they get funny looks on their faces when I reply "The direction represented by the vector sum of all gravitational forces applied to a given body at a specific point in space and time." Sqrt (X^2+Y^2+Z^2)
