thorlabs stage communication error with MG17Core.dll
I'm working with thorlabs stepper motors, and I'm having a problem with an error message occurs at random times.
The program will run for an hour perfectly fine, then crash with the error code 10110. It says "hardware notification/response, MG17Core.dll internal code = 16240903."
I'm having trouble figuring out what is going on, thank you in advance for the help.
(1,814 Views)
Shouldn't you be asking Thorlabs?
(1,809 Views)
I thought it couldn't hurt to ask here as well.
(1,802 Views)
Hey purschke,
This is Henry from NI and I think it would be helpful to ask Thorlabs about this error as well.  The particular error code 10110 is a undefined error which could likely be due thrid party objects. If you find out this is not a thrid party error then you can either open a new post or repost back into this forum with further details from Thorlabs.
Best,
Henry
(1,751 Views)
Hi! It's ARanyak. Have you already identified your mistake....because now I am facing the same problem too. It would be a great help if you can address the solution. Thank you.
(1,464 Views)
It was created by thorlabs, may be they got something about it
(1,444 Views)
