thermocouple and humidity sensor measurements using 9211 and 6008. Help!!
I've got a 6008 connected to a humidity sensor and a 9211 connected to 4 thermocouples. I want to take readings every 15 minutes for 24 hours. I've got labview and DAQ set up and both 6008 and 9211 are recognised. I've added the steps for both but keep getting error messages when trying to 'run'. How do I get labview to take these measurements for the said time period so I can get a graph of temperature vs. moisture content? many thanks, Niall
(2,967 Views)
You're not giving us much info to help you.  Post your code and describe the errors you're seeing.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,959 Views)
DO you have the code so that we can take a lok at it?
Tim
GHSP
(2,955 Views)
He mentions 'steps'.  Probably DAQ Assistant???  If so, use the open front panel option to generate labview code we can look at.
(2,952 Views)
