there are no notifications for your produce
Hi
I have now  Lap VIEW 2013 and I tried to dowload LabVIEW Control Design and Simulation Module after following the process a message shows that "There are no notifications for your products". Even if I have closed window firewall and setted the files enables to install in my computer. I still was able to get this function in my labview.
Do you guys have this experience and solution?
Thanks a lot
(6,875 Views)
Extra information I use Lab VIEW 2013 Student version.
(6,872 Views)
I don't see an issue.  Part of NI's install process is to check their site to see if there are any critical bugs that they found in the version you are installing.  There apparently were no notifications about critical errors, so you got the "no notifications" part of the install wizard.  Just keep hitting "Next" to finish installing.
(6,835 Views)
@Tullip wrote:
Hi
Thanks a lot
Hi, your wording isn't quite clear to me.  Does everything actually work?  The "No notifications..." message is simply telling you that your stuff is up to date.  🙂
Bill
CLD
(Mid-Level minion.)
(6,832 Views)
Hi
After I clicked next bottom until finished all process but in the labview Control design and simulation function is empty. I don't know what a problem.
(6,780 Views)
(6,752 Views)
