the stop button is not responding when i needed to stop a program
respected sir it is showing one error which i m attaching below.... actually the thing is that in this write and read are executing serially...i wnat to make them work parallelly.....but when i tried for parallel it weas having large delay.......so i want this delay to remove so that it works aquickly....
error attachment is below n also the real program is attached below,,,
Message 21 of 22
(798 Views)
Accepted by topic author thakurshubh
It is NOT helpful if you re-post the same thing over and over again! You already posted the same attachments earlier.
"Insanity: doing the same thing over and over again and expecting different results." Albert Einstein (maybe)
As I said you need to find out what the actual instrument reponses are. I cannot help you with that, because I don't have your instrument or documentation.
@thakurshubh wrote:
ractually the thing is that in this write and read are executing serially...i wnat to make them work parallelly.....but when i tried for parallel it weas having large delay.......so i want this delay to remove so that it works aquickly....
I have no idea what you mean by that! You have a single serial communication channel, how are you expecing to use it in parallel? It makes no sense!
Message 22 of 22
(784 Views)
