the order of variabels inside a cluster
Dear
I made a cluster constant in the order of A, B and C constant variables.
Because of changing from the cluster to a array form,
I had to consider carefully and then change to B, A and C constants.
Therefore, I edit the cluster first, but the order of variable can't be modified.
Would you please how to redefine the order of variable in a cluster?
Thank you in advance.
Lee
(2,745 Views)
you can redfine the order of variable in a cluster by dragging out the variables form the cluster container and reinsert it again...cluster automatically assign the order to varable when you put the varaible in container..
(2,740 Views)
To reorder the elements of a cluster, right-click on the cluster and select "Reorder controls in cluster...". Now click on the element in the desired order, then click the confirm button to finish.
(2,731 Views)
Right-click on the cluster, select Reorder Controls In Cluster..., then click on the controls with the desired order until satisfied and click OK to confirm.
Optionally, reorder controls placement by right clicking again and selecting one of the options in Autosizing...
Paolo
(2,730 Views)
