the FP custom create tag VI. shows an error code 32830 when i am runniing my aplication.
what does it mean and how to solve? I seem to be having problems talking to the FP-1000. I generated a .iak file using FeildPoint Explorer V3.01 with no problems I can talked and get readings from my FP-AI-100 using the Explorer software but not any of the LabVIEW VI's, also i have generated the FP custom create tag without problems, but it shows code error 32830 when i am running the aplication.
(2,733 Views)
Omar,
There is a limitation of how many programs can access a serial port at the same time. When FieldPoint Explorer is open, LabVIEW will not be allowed to use the serial port. Thus, if you close FieldPoint Explorer, you should be able to run your LabVIEW program and not get the 32830 error.
Aaron
LabVIEW Champion, CLA, CPI
(2,733 Views)
ok Aaron !
you are ok,thank you !
Nice day !
(2,733 Views)
