i am using initialization VI to initialization a stepper motor and PMW signal output to the Arduino pin 5,6. the issue is that after the inti vi the pins 5,6 are at set at high voltage and i want them to be set to zero to start actuating the motor and pmw signal at the same time. i will use PMW signal to control air valve that should start working at the same instance of motor actuation
