test PC Setup with labview, teststand & PXI rack
I couldn't decide which forum to post this under so my apologiies if this doesn't totally fit...
I am attempting to resurect a test PC that was used to launch LabVIEW 2014 & 2014 VIs from 2013 & 2014 Teststand and uses devices mounted in
a PXIe-1065, 18-Slot 3U PXIe/PXI Chassis, but the hard drive was lost and the back up proved to be worthless...
So far I was able to configure the NI DAQmx and VISA and can access the modules in the PXI rack through NI MAX.
I used to be able to click on a desktop shortcut to a test stand sequence file which would then open up a copy of teststand
with the sequence file steps showing where I could execute a test with that sequence file but I am struggling in my attempts
to restore this feature.
I have a base deployment license on this PC but need to know what other national Instrument software or drivers that I need
to install in order to deploy labview 2013 & 2014 VIs from teststand  2014 which use the devices in a PXIe-1065, 18-Slot 3U PXIe/PXI Chassis.
(run time engines, other software??)
Any timely information is greatly appreciated.
Thank you for your time
Message 1 of 1
(2,408 Views)
