tektronics- wave form single trigger
Highlighted
Hi all,
I am trying to capture a rigsing edge waveform. Tecktronics drivers do not have single trigger.
Is there any way that I can do a single trigger and then save the savefrom on the screen.
A digital IO is used to control a converter to generate an edge.
Thanks!
Message 1 of 14
(1,064 Views)
Highlighted
@tian66 wrote:
Hi all,
Thanks!
Are you sure?  That has to be one of the most common things you do on an o-scope.  Other than continuous trigger, of course.  😉
Try looking at the drivers again.
Bill
CLD
(Mid-Level minion.)
Message 2 of 14
(1,059 Views)
Highlighted
There are most certainly trigger functions with all of the Tek drivers I've ever used. Look again. Of you can manually configure an external trigger, you can do it with a program.
Message 3 of 14
(1,054 Views)
Highlighted
I cannot find it in the driver. I think the attached VI has all of the trigger function.
Besides, I need to capture many rising edges and I hope it is done automaticlly.
Thanks!
Message 4 of 14
(1,047 Views)
Highlighted
 Please refer to the following attachement
Thanks!
Message 5 of 14
(1,045 Views)
Highlighted
Thanks!
That picture is making me regret I ever saw this thread...
(And it's not because of the drop-down menu.)
Bill
CLD
(Mid-Level minion.)
Message 6 of 14
(1,037 Views)
Highlighted
Since there are obviously trigger functions in the driver, I don't understand what you are asking for. Have you read the scope manual on how to configure a trigger? Have you done it manually?
I also see a sequence structure in your small image. Certainly not necessary.
Message 7 of 14
(1,027 Views)
Highlighted
I want to do the Single trigger at the rising edge so that the osciiloscope stops at momnet and then capture that waveform from the scope.
I can manully press the Single to trigger the rising edge and it kept on the screen,  but no clue on how to do it in LabVIEW. The rising edge is about several ms.
thanks!
Message 8 of 14
(1,020 Views)
Highlighted
After configuring the vertical and horizontal, do you configure the edge trigger? Do you do an initiate? Pressing the trigger button on the scope is not at all the same thing as using an external trigger.
Message 9 of 14
(1,005 Views)
Highlighted
Yes. I do. but I did not initiate it. Right now the problem is I cannot figour out how to stop the waveform at 50% threshold in labVIEW and then save it.
On oscilloscope, it is obvious. Set the trigger channel, threshold value, then press "Single". The waveform is there.
Thanks!
Message 10 of 14
(992 Views)
