tds 3054 driver, ethernet problem
I found the driver on NI website (plug & play (project style)). Can't get it to work with ethernet. It looks like you don't have to do anything if you are using Serial port, but the problem is that I only have ethernet on the scope. I'm not really sure where to start. In the Visa Resource Name drop box, I changed the Visa Class I/O sessions to TCP/IP Inst. ( I did this in all sub Vis) and this did not help with anything. Any suggestions? Where do I start?
(2,140 Views)
All I had to do is add a TCPIP device in MAX. all works now
(2,136 Views)
