From 02:00 AM CST Saturday, February 4 - 06:00 AM CST Saturday, February 4, ni.com will undergo system upgrades that may result in temporary service interruption.
take a photo using a laptop or USB camera in LabVIEW
has anyone used a USB or built-in laptop camera to take a photo in LabVIEW? If yes, can you please share the code? Appreciate it.
Thanks.
Ian
(2,183 Views)
I am not talking about using a specialized camera which needs to use a specialized LabVIEW toolkit, instead, it might just be some Microsoft Windows built-in calls. Just like what "Microsoft Camera" App does.
(2,164 Views)
The easiest way is to use IMAQdx which is part of the vision acquisition toolkit. (Warning: this requires a separate run time license if you want to run in  an executable on another machine, ~£400 from memory)
This link lists to compatible camera protocols: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6COSA0&l=en-GB
Do you have access to this module?
Edit: Further thoughts....If you don't have access to this module or your camera isn't compatible, you may be able to get dll's from the camera manufacturers website or use an open source sdk, see this thread
https://forums.ni.com/t5/LabWindows-CVI/How-to-Acquire-an-Image-without-IMAQ/td-p/2491124
(2,130 Views)
Accepted by topic author TulaRen
(2,115 Views)
Yes, that's exactly what I am looking for. Many thanks.
Ian
(2,094 Views)
