Hi and thanks for the response.
I think I may have explained the behavior i'm seeing wrong. Changing the tab order, you have those two little boxes the first showing the changed order number, and the black background one that shows what it was previously. Each time you change one, yep you have to change the order of the rest otherwise you might tab and select two fields at once!
The behavior I'm not sure about though, is when I change them to the proper order on the front page, it changes my block diagram. For example if I have a cluster with 3 items in it, and I change the tab order of the items inside that cluster. Then if I had previously used an "unbundle" function prior to the tab order change, and it was all wired up with item 1 at the top, item 2 in the middle output, and item 3 as the bottom output - AFTER the change, those controls are no longer at the same outputs. Given this, if they already had wires coming off them, i'm now sending an incorrect value to the wire attached to that output (since item 1 might no longer be on the top output)
(Can be recreated with a simple VI with 1 cluster as above, with an indicator off each. Write a string in each one, output to indicator, then change tab order but nothing else and rerun. Now the bundle changes.)
I'm not sure how it would behave with an "unbundle by name" but in this case I need the "unbundle" several times...which is making for a pain if I want to use the tab control.
LV7.1, LV8.5, LV2014/15/16
